Results 1 to 15 of 23
    Default PVC pipe sound dampening
    Anybody know of another way to dampen the sound from a pvc pipe in a wall and floor (bathroom waste pipe) other than wrapping it with insulation. Other materials? Thanks.
    Chicago, IL
    210
    Default Re: PVC pipe sound dampening
    Use a sheet of quiet rock over the bay with the pipe in it.
    http://www.quietsolution.com/
    Around here this runs about 80/ sheet. make sure to use the appropriate caulk at the edges of the joist bay.
    Apr 2006
    NYC
    38
    I've heard of ice&water shield or quietblanket (sound deadening material used in cars) being used. It works well, but I have no idea about the long-term issues.
    We spec PVC vents and fittings with no-hub to cast iron branches and stacks. Its quiet and about 1/2 $ of a complete cast job.
    Oct 2007
    Southern California
    2,184
    Well, replacing it with cast iron is the easiest way, if you can get to it without too much trouble....
    Apr 2007
    southeastern South Dakota
    1,743
    We had a contractor that had us sheet both sides of the stud cavities with valley tin and fill the cavity with sand. I'm not saying that's what you should do, but it worked very well.
    Mark
    Northern Vermont
    1,381
    Mark,
    And each time someone slammed the door in that partition, a little more sand leaked out of the stud bay ....
    Nov 2007
    Dallas,PA
    1,065
    Maybe try 2" thick rockwool batts adjacent to the pipe and a layer of 1" shaftwall drywall next to that followed by the finish layer of drywall. Wherever the pipe penetrates a joist, isolate it with foam pipe wrap. Thick and dense materials will go the furthest in killing off this sound.
    Otherwise you could use a high density fiberglass and a mass loaded vinyl mat but the material is significantly more expensive than the drywall and rockwool approach.
    "ALS IK KAN" - Stickley
    Oct 2005
    Oakland California
    43
    You can buy some spray foam in a box. Spray a couple of inches around the pipe of in the cavity.
    Oak Park, Illinois
    463
    Studio:
    In my house I used sheet lead in a 2' roll supplied by my plumber. It has worked great. I would think that the 1" "core board" as we call it around here would work well if you have the room to inset it.
    Core board is also referred to as shaft wall, a 1" gypsum product sold commercially in 2' x 8' lengths.
    Good luck,
    RJC
    Every job is a self-portrait of the person who did it. Autograph your work with quality.
    15,171
    RJ:
    I've got to agree with you, when ABS became legal here for DWV I used it in a two story home, after it was complete the customers invited the wife and me over to dinner, ostensibly to show their appreciation for the house. In the middle of dinner one of the twin children excused himself, got up from the dining room dinner table, went upstairs and flused a toilet, it sounded like Niagra falls in the formal dining room. I got the message and sent some men back, tore out one side of the 5/8" sheetrock and had the plumber put cast iron between the floors. Shortly after I was building a hospital and when installing the lead-lined sheetrock in the radiation suite I noticed the tremendous sound deadening effect, I always wondered if I had just put another layer of lead-lined sheetrock on that wall if it wouldn't have saved me a lot of time and money; however, I've read the specifications on the lead lined sheetrock and USG says nothing about sound attenuation, I've called them and they just say they've never tested it for sound deadening. That was the one and only time I've ever used plastic pipe (except for perimeter drains around the foundation on the outside of the house).
    When fascism comes to America it will not be in brown and black shirts, it will not be with jack-boots, it will be in Nike sneakers and Smiley shirts. Germany lost the Second World War, Fascism won it. George Carlin 1937 - 2008
    Nov 2007
    Dallas,PA
    1,065
    Lead does work well, again because of the density, but the last few sheets I bought about 5 months ago were in the $ 12.00/sf range. The shaft wall is much cheaper and is readily available at any decent drywall supply yard. As RJ described and as I inferred in my earlier posting, the shaft-wall would be inset between the joists or studs on wood furring or perhaps 25 ga. utility angle screwed to the side of the framing.
    As commodity prices have come down recently, we may see the lead price decrease in coming months as old inventory gets sold off.
    Georgia
    1,825
    I think I read a few months ago that there is a brand of PVC DWV pipe that is designed for sound control. I wish I could remember the name of it.
    Apr 2007
    1,743
    Quote Originally Posted by Martin Holladay View Post
    Mark,
    We told the GC we thought that would happen, but he insisted. The reason pvc and abs make so much noise is that the pipe resonates like a guitar string as the water runs down the inside of the pipe. The water spirals down the pipe and causes it to vibrate. What you hear is an amplified sound. Shorter pipe higher pitch, longer pipe lower pitch. Smaller diameter, higher pitch, larger diameter, lower pitch. I would think low expanding foam shot into the stud cavity would dampen the vibrations enough to virtually cut out the sound.
    Mark
    Chicago
    3,599
    Quote Originally Posted by calvert View Post
    Wouldn't a couple of layers of standard 5/8" drywall work just as well or better than core board?? Sure, core board is not hard to get, but how is it going to be better? Seems like two separate layers would give better sound-dampening anyway.
    Oct 2008
    Rumson, NJ
    379
    Way up top, Total Home posted a link to Quiet Rock. This one might also work.
    http://www.quietsolution.com/html/quietrock.html
    This stuff is engineered for exactly this purpose, and it weighs no more than regular 'rock. Skip the multiple layers of 1" rock, sand, lead, etc.
    Peter Engle, PE
    Almost Home, Inc.
    www.almosthome.com
