Results 1 to 4 of 4
    May 2006
    Miami, FL
    1,155
    Default Seams bleeding through the paint
    I went to my job today to lay carpet tile out, and notice one wall where the joints flashed a light yellowish line, the size of a tape from top to bottom. 4 lines on the entire wall, which where 4 joint. All stand-ups. Land-lord finished these walls a year ago. They where meshed taped. I primed with Sherman Willaims Pro Block and painting the wall a white color, egg shell finish. After 2 coats of paint on the walls, I was done. However, today we notice the yellow lines, the size of a piece of tape running from the top of the wall to the bottom. Could it be some water got behind the wall and caused this to happened. The area has had the AC running all the time, but no other walls have this problem. I checked above the acoustical tile for a leak, but everythign checked out good. Weird. I'm going to have to hit it with some killz.
    Default Re: Seams bleeding through the paint
    I had a had the same problem if your joints are even a little wet when you prime it will flash i switched to kelly moore 95-100 primer and it solved the problem
    New Haven, CT
    977
    Quote Originally Posted by austinzilla View Post
    I had a had the same problem if your joints are even a little wet when you prime it will flash...
    Just the tape will flash? The way he describes it, it's a 2" wide line. I've never seen anything like that.
    Beer is proof that God loves us and wants us to be happy. -- Benjamin Franklin
    May 2006
    Miami, FL
    1,155
    Yes just the tape flashes, and its with mesh tape because I can see it at the bottem near the floor.
