Results 1 to 15 of 17
    BOSTON, MA
    193
    Default ceramic tile install next to a wood threshold
    Whats the best way to install a ceramic tile next to a wood threshold?
    I was thinking of cutting the edge of the tile at angle? make sense or am i off.
    Normally just to carpentry but this job involves laying some ceramic tile in a small room.
    thanks
    315
    Default Re: ceramic tile install next to a wood threshold
    If even, caulk it, if uneven height, T molding to match the wood.
    Georgia
    1,826
    You call that T-molding a match?
    315
    Closest they had and customer bought and picked it, I just installed it, just giving an example of what can be done.
    Next question.
    North East
    470
    zoom in on the title of the top book and thier choice for the mismatched molding is explained.
    Aug 2006
    SE PA
    504
    Quote Originally Posted by charles View Post
    What do you mean? What would you suggest?
    Other than it being pieced (or looking like it) on the left side, it looks fine in my opinion. So please tells us what the problem is that you see.
    Thanks.
    Clifton, NJ
    2,385
    As to your original post, I would remove the threshold and fabricate a transition strip. This is how I handle it when my tile contractor and I do a bath floor to hardwood bedroom. I custom fabricate something that takes care of whatever, high tile, low tile, even tile.
    The t molding might be made that way, not pieced.
    The base moulding and door sill, however look like they need some detailing.
    SteveC
    Dedham, MA
    345
    Quote Originally Posted by user843839 View Post
    Thanks.
    I think the "match" comment was on color.
    And is that really pieced in like that?!
    -Sean
    North East
    470
    It does look like an example of a short sighted HO Solution.
    HO
    "Home depot only had a 36" wide T molding. The good news is I bought a second one so you can cut 1 1/2" from it."
    Aug 2006
    SE PA
    504
    Quote Originally Posted by StephenS View Post
    One of the things I've learned about opur industry is that there are lots of preople who will walk in behind another contractor and talk about what he did wrong and how it should have been done. However, moday morning quaterbacking never seems to take into account all the issues the original guy was trying to deal with.
    So, in the spirit of trying to learn something, here are my questions:
    1.) OK. Now please be specific and tell us why, in your opinion, "it looks like an example of a short sighted HO solution"
    2.) and what specifically would you have done differently (how and why)?
    As far as the comment about color, I don't know how one can run a piece of oak of any shape or section perpendicular to the existing multi-colored oak strip flooring and get a color match? I would love to know how to do that.
    Thank you.
    Sincerely,
    North East
    470
    Tom,
    My comments are not directed to Tileman or any contractor. Tileman has shown through this site and John's an abundance of elite setting experience.
    Keep in mind, I'm basing my post on my observation that the molding is pieced. A short sighted HO is one that will buy or bring materials to a project that thier "good" with at the time of installation however a month after thier eagerness to have the job finished quicker than later has faded, they're no longer "good" with the result. I've heard one too many times that "It won't bother me" or "just install it, I'm too busy to goto another store" or even "I asked the clerck and he said they don't carry it" I bite my lip on the last excuse as I know HD's stock and at that point It's waisted breath to suggest going to the local lumber yard.
    My calculations has the transition at 37.5".. My hunch is the HO popped into a hardware store or big box store, found the 3' transitions and made a quick descision to piece it prior to looking far left or right for the 6' length..
    Color match is in the eye of the beholder. Oak wood has alot of variation of grain and color to the point a good pick blends and a not so good pick sticks out..
    Next time your at HD, head over to the prefinished solid oak transitions and set out 5 parrellel to each other 1/2" apart on the ground. Step back and you'll see what I'm speaking of. It's not always simple though the issue is that an inexperienced person might not even think of trying to get a good fit..
    Feb 2007
    Philadelphia, Pa.
    1,510
    Tom,
    The floor is a "Golden Oak" color, and the threshold only has a clear coat on it. They're two different colors period. There's no "moday morning quaterbacking" as you spelled...err... put it, going on here. It's simply a home owner taking the easy route and just getting what the store had in stock and throwing out the ol' "good enough" phrase.
    Has someone picked apart your work recently or have you been in those political threads to long? You seem highly argumentative over something that's really silly JMHO. [shrugs]
    EDIT: Stephen posted while I was typing.
    -Dennis
    315
    Amazing how far this has gone, I'm sorry I posted that photo now, I was just giving the original poster an idea to answer his question.
    Scheeesh, I'm sure that if everyone here posted photos of all their work, I could rip em all apart also.
    Feb 2007
    Philadelphia, Pa.
    1,510
    Quote Originally Posted by Tileman1 View Post
    If I posted my tile work, I think you would be laughing to hard to pick it apart. :0)
    -Dennis
    Apr 2008
    Calgary Alberta Canada
    61
    I invested in a portable router table which I use either on site or at home and I fabricate the mouldings I need if I can't find them at the hardware store.
    Takes a little while, plus I have to stain to match then lacquer them, but when the customer wants wood to match, it can be done.
    It is good for stair nosings as well which I then use screws and wood plugs sawed flush to attach.
    Schluter is another method for those whose preference is metallic.
    By the way, nice granite job tileman1. Just finished a travertine shower over kerdi (12x12) done the old way. Lots of sweat. I am certainly going to get that system for the next one.
