Results 1 to 15 of 21
    Oct 2007
    Portland, Oregon
    1,175
    Default Modified vs unmodified thinset
    What is the difference? Are they for different applications?
    Default Re: Modified vs unmodified thinset
    That's a big topic. I suppose to cover the basics you can say that modified is stickier and stronger, and it's what you want to use with porcelain tile.
    Oct 2007
    Portland, Oregon
    1,175
    Ok, but my thought is then why do they manufacture unmodified? Are there applications where modified would be unsuitable, and you would need to use unmodified?
    May 2006
    NJ
    5,832
    Unmodified is used in applications where there is the inability for the moisture to evaporate through the either the substrate or the tile above.
    For example....where tile is installed over Ditra. The thinset is sandwiched between the ditra (plastic) and tile and has little surface area for the moisture to escape and allow for curing, so an unmodified thinset is used because it will cure with minimal or no availability for the moisture to evaporate.
    This is what the representative from schluter explained to me at a show a few years back.
    Look at this diagram on page 12
    http://www.schluter.com/media/DitraH...9-2007-ENG.pdf
    Chuck
    Apr 2008
    Calgary Alberta Canada
    61
    Sometimes it is just the expense. Why spend money on polymers which are not needed.
    When you are installing over concrete that is sound you do not need modified mortar as it will stick just fine and will not be subjected to flexing, but on plywood floors where movement is likely it is best to use a high grade thinset with lots of admix.
    Alberta, Canada
    517
    If you read discoloration in light grout you will learn from our mistake that unmodified thinset is suitable and unmodified not suitable for when using the Kerdi/Schluter system.
    Nicole
    Los Angeles, CA
    4,264
    Quote Originally Posted by Nickymg View Post
    Nicole
    I read this twice and can't understand it. Is there a typo or am I just tired?
    Alberta, Canada
    517
    I think I am tired - it does not make any sense at all! Sorry, do not worry about it. I am not tile expert.
    Nicole
    Apr 2006
    Central Coast, California
    1,170
    Dry-set thinset mortar has no polymers and is basically sand, cement, and some retarder. It is the first thinset mortar developed (no, it was not engineered specifically for Schluter products). You can add a liquid latex or acrylic in place of water to make a modified thinset. Dry-set thinset mortar will not stick to wood after curing.
    Mar 2008
    Jacksonville, Fl. (Dinsmore)
    236
    Are you sure about those facts Mr. Byrne? I thought Herr Schluter invented unmodified after creating the Internet with Mr. Gore? :)
    Aug 2006
    492
    Quote Originally Posted by mbyrne View Post
    Mike, could you explain this a bit more. I don't understand what you mean by "dry-set thinset mortar". But since I'm just a GC, not a tile setter, I think you will understand. Thank you.
    Regards,
    "The problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts." B. Russell
    "An imbalance between rich and poor is the oldest and most fatal ailment of all republics." Plutarch
    Los Angeles, CA
    4,264
    Thinset morter, when "dry" will no longer adhere to plywood. That is why modified was created.
    Mar 2008
    236
    Dryset mortar and unmodified is the same thing.
    Aug 2006
    492
    Quote Originally Posted by scuttlebuttrp View Post
    Thank you! Now I understand.
    6,549
    Quote Originally Posted by always-learning View Post
    That's a good-sounding theory but it doesn't hold any water (pun intended).
    Custom guarantees modified over Redgard. Actually they require it. From Redgard data sheet:
    TILE INSTALLATION
    Install tile or stone with a Custom® polymer-modified mortar meeting ANSI A118.4 or A118.11 standards.
    Schluter must know something we don't. Or they may be relying on technical advice from Mr. Gore :)
    dg
