Results 1 to 15 of 32
    Oct 2006
    michigan
    195
    Default pre-cut stringers
    I have no problem calculating and cutting my own stringers, but for exterior deck work, where you only need 2 - 3 steps, those pre-cuts I see at Lowes and Home Depot look like a bargain.
    Any disadvantage to using them?
    Bob
    6,740
    Default Re: pre-cut stringers
    Problem is that it has to be the right height for the steps to work. I thought I could use them several times and find out that often I need something just a bit different in size. Last one I needed something like 6 3/8 risers to make it work out. Still ended up cutting my own stringers.
    Northern Virginia
    198
    A stringer is a stringer all made of pressure Treated material but you are probably not going to get the desired layout for your deck and need to fill dirt in under the last step to make up for the difference.
    Depending on how you lay out and build your stringers the riser and tread material may not work out to what you need either.....I usually do a 10 3/4" Tread and try to get a 7" rise but that doesn't always work.
    This way I can get two 5/4x6 deck boards on the tread over lapping the 1x riser board and give a small nosing on the tread........
    Justin Thomas
    Northern Virginia
    198
    m beezo,
    beat me to it!
    Justin Thomas
    Bergen County NJ
    1,966
    nevermind... stack a few together and i bet you have differences of upto 1/4" in the cuts i used them a few times and had to plane them to match each other.
    i don't use them anymore i just use my prazi and cut mine all exactly the same on the first try.
    -Sal
    ___________________________
    BSA Renovations
    www.BSA-Reno.com
    Sep 2006
    Western Mass
    1,623
    Sal,
    thanks for pointing that out. I will know tomorrow if I have 32 decks to frame and I was thinking those would be a real time saver. Guess not
    Lou
    Bergen County NJ
    1,966
    Big Lou
    if your doing that many decks grab a prazi - if you don't already have one - trust me you will not be sorry. i can't tell you how much time it saves... especially with stringers.
    one down side with it is be careful with the blade they can dull real quick if you touch some metal. i am about to buy a chainsaw sleeve or make one to protect the blade.
    god i love tools ;-)
    i think someone is working on a prazi review in for a future JLC ;-)
    -Sal
    BSA Renovations
    www.BSA-Reno.com
    6,740
    Quote Originally Posted by BigLou80 View Post
    Sal,
    Lou
    That is a lot of decks. All at one time? If you do that I want to hear back on some of your techniques to make it go quicker/easier/better. I have never built more than 3 decks a year, each one so different from the next that it is almost a new learning experience each time.
    Was wondering if you can consider coming up with one design and then get it down to where each one gets a little faster to do?
    Oct 2006
    michigan
    195
    You guys are right - I relocated the steps on a deck last spring and came out with perfect rise/run with the help of a Construction Master calculator. Pre-cuts would not have worked.
    And I've seen some DIY jobs where the first step is a 12" rise, followed by several 7" risers, ending with a top step of 4.5" - try getting those passed.
    Regards, Bob
    Sep 2006
    Western Mass
    1,623
    Sal,
    thanks for the advice I will definatly do that
    mbeezo
    they are more or less all the same its for a condo association. to make this profitable we will need to get a lot of production. Thanks to this site and people like Tim Uhler and others I now feel confident in out ability to do this .
    Lou
    Caldwell, NJ
    3,153
    Quote Originally Posted by bob14-0 View Post
    Bob,
    That's because they are precuts and they are cut a a fixed rise. If you don't have that exact rise, they wont work. You could however use them if you were adjust the grade to make them work.
    I've never once used precut stringers or ever once seen a contractor use them. The only people who I've seen use them are DIY'ers.
    Joe Carola
    Bergen County, NJ
    4,410
    Do the precut stringers come with the bottom riser 1" shorter?
    I bet not knowing Home Dopey.
    May 2007
    right around the corner
    1,609
    Quote Originally Posted by Greg Di View Post
    Now don't go helping the 1000's of lurkers watching this thread now lol
    JASON
    George S. Patton
    Dedham, MA
    345
    The bottoms on those are cut 1" shorter. But they are never consistent.
    What's this prazi you speak of?
    -Sean
    May 2007
    1,609
    Quote Originally Posted by A.P.G.C. View Post
    Ahh a necessity to any one who works with multiple sets of dimensional lumber
    http://www.google.com/search?q=prazi...ient=firefox-a
    JASON
    George S. Patton
