Results 1 to 15 of 15
    Oct 2004
    Rhode Island
    315
    Default 1" black pipe max psi
    Kind of an odd question, but does anyone know or have a good guess what psi can be put thru 1" black steel gas pipe?
    RJ Perry
    Liberty Construction LLC
    Warwick RI
    South San Francisco, CA
    184
    Default Re: 1" black pipe max psi
    I have a "little black book" of various reference charts and specifications, and it states that standard schedule 40 steel pipe 1/8" to 1", continuous weld or seamless is good up to 700psi.
    steve
    Jun 2005
    Dutchess County, New York
    982
    What do you plan on using it for?
    PRAY FOR OBAMA.....Psalm 109:8
    http://www.cstonecarpentry.com/
    2,196
    Just make sure you don't buy the crap coming out of China.
    Talking about China, The last cast iron tub (5-1/2' American Standard) we installed was made in China.
    They need to change their name to "China Standard"
    Hathaway Pines, California
    149
    When I was just out of High school I worked for a utility company and we ran miles of 3/4" black pipe. I was always told the top pressure was 175 PSI, but the working pressure was much lower. This seemed more like a "working rule" rather than anything scientific. For high pressure we always used heavy wall pipe and fittings. In my own shop I use 3/4" pipe for all my perimeter air lines and run it at 135 psi with no problems. Good luck and be careful.
    Don
    14,201
    I was surprised to hear, from a local gas utility man once, that gas pressure within the pipe was only 4 psi. this isn't really on point, but it bears that out by referring to pipe capacities with pressures over 5 psi. So I wouldn't assume that existing gas piping could handle high pressure air for example.
    This seems like an extremely good question for a pipe manufacturer.
    Oct 2004
    Rhode Island
    315
    I was watching american chopper the other night, and they made a potato gun out of copper. As I was strolling thru HD I figured Id make one out of steel threaded pipe.
    RJ Perry
    Warwick RI
    970
    PVC will work fine for that.
    Geoff
    Sep 2006
    Western Mass
    1,623
    i always use pvc
    Oct 2004
    Rhode Island
    315
    I saw ones made out of pvc before online, and that setup used hairspray and an ignitor or something similiar. They one they made and I made has a chamber to store the air between two valves. Open the first on to fill with air, close that when the gauge shows whatever pressure I want, the the second valve to release the air.
    Here are a couple pics
    http://picasaweb.google.com/podge58977/PotatoGun
    RJ Perry
    Warwick RI
    Los Angeles, CA
    4,264
    We used to use two tennis ball cans, a sparker from a lantern and shoot tennis balls.
    Oct 2004
    SF Bay Area
    1,338
    PVC 4" combustion chamber with a BBQ igniter 2" barrel ;0
    Kye
    Jan 2008
    Cincinnati
    425
    Mine is 4" & 2" sched 80 tubing, sched 40 fittings, grill ignitor to long reach fine tip NGK spark plug.
    I built it about 12 years ago, & couldn't count the number of shots!
    I would recomend a healthy tight wrap of duct tape around the tube bottom, as added insurance. It can't hurt, & may prevent a blow out!
    Joe
    The pressure of the black pipe you are looking at is normaly rated at 700 psi
    What limits the rating is the pressure rating of the fittings used with it
    150# WOG, Water, Oil, Gas Black or galv.- 125# steam sch40 A53cw pipe
    250# WOG -175# steam sch40 A53cw pipe
    2000# wog -600# steam w/ sch80 pipe a53cw pipe or smls pipe a106
    3000# wog- 800# steam ditto
    6000# wog - 1200# steam ditto
    hope this helps
    garth merrick
