Thread: Scaffolding Estimating
03-09-2008, 07:53 AM #1
- Mar 2008
- 2
Hi
Can some scaffolding estimator expert tell me please which software is best and easy for estimating scaffolding of new build building?
Many thanks
03-09-2008, 08:26 AM #2
Moderator
- Holly Springs, GA
- 3,286
Re: Scaffolding Estimating
I don't think I've ever seen software specifically for estimating scaffolding- it's a pretty "unscientific" item to estimate unless you're talking about scaffolding the Empire State Building or something- divide the length of the wall needing scaffolding by the length of each frame, divide the height of the wall by the height of each frame, and multiply the two to determine the number of frames you need. What exactly are you having problems with?
03-09-2008, 09:32 AM #3
- Friday Harbor, San Juan Island, Washington
- 13,029
Bob, when I used to have scaffolding put up they used pipes not frames and there was often a lot to it. Stair towers, cantilevers, trusses over the garage and/or front porch, up and down the hill, etc.
The guy who priced them figured the rent on the material, and he figured a crew would take a day to load up, drive, and set up one job. Then they'd take a day to strike, load out, and clear a job. These were average to large houses.
03-09-2008, 10:24 AM #4
- Jan 2007
- Louisville, KY
- 3,565
Who ever you plan to rent the scalfold from should be able to help you with this.
I'm currently working with a company and they are pretty much telling me what I need and how much it will cost. There giving me a couple options also to chose from.
04-04-2008, 09:35 PM #5
- Jan 2007
- North/Central FL
- 784
I use Brand Scaffolding, a nationwide company that rents scaffolding, sells, designs on complex jobs, and does E & D. It's one of those things that I'd rather not worry myself with. They also deal in shoring. A full service scaffolding contractor will also minimize your exposure to OSHA liability by supplying a complete product.
02-23-2012, 02:02 AM #6
- Feb 2012
- 1
This site shows the scaffolding calculator
http://www.scaffold-sales-online.com...Calculator.htm
02-29-2012, 07:03 PM #7
- Branford, CT 06405
- 3,459
I imagine if you wait a day or two, the guy from India will show up and explain all about scaffolding to you!
Take Care
03-21-2012, 09:59 AM #8
- Sep 2004
- 5,612
Deleted........
04-13-2012, 08:43 AM #9
- Apr 2012
- 1
Quality Construction Equipment! Scaffolding Direct
