Results 1 to 15 of 16
    Oct 2007
    Midlothian, Va
    72
    Default Coffered Ceiling Materials ??????
    Hello to all !
    I'm finally getting a chance to install a coffered ceiling using the method Gary uses. I've read all of the articles and have Gary's book. But if people reading this forum who have completed coffered ceilings could talk more about the materials they used for the backing and the beams. Gary recommends finger jointed pine/jamb material fro the hollow backing and mdf for the beams. I'm having difficulty finding mdf in plank form where I live(and i don't want to rip down loads of tall baseboard). The beams are going to be six inches wide, are there any other suitable light weight stable material you can use?.
    THANKS
    brian
    Charlotte, NC
    120
    Default Re: Coffered Ceiling Materials ??????
    ... very nice...
    Donald
    Sure Lock, Inc.
    __________________________________________________ _____________
    "Always do the best work possible. Leave the job-sites saying, 'I did great work today!' And you should be charging in the top 10-20%. Your customers will be saying, 'That guy is very expensive! But he's worth it!!!' ". -GK
    I used finger jointed pine (pre-primed) for both Beams and backing. Used 1x6 material in 16' lengths and just cut to fit.
    I allowed material to acclimate for a week, then used plenty of glue for all the joints. Job came out excellent.
    See attached.
    Oct 2007
    Midlothian, Va
    72
    j,
    yes it looks fantastic, does it have to be pre primed for the hollow backing?,
    thanks
    brian
    ask stupid questions, don't look stupid later.
    Northern Virginia
    78
    I am in the process of doing a library right now and just finished the coffer ceiling.
    I did it a little different than Gary shows in his book, but he was HUGE help with the process and credit a lot of it to him.
    I did the braces like he shows, but then used 3/4" ply for the sides and beam bottoms. I assembled the beam sides on the floor, then lifted them up and nailed them. I then used cap moulding to cover the ply edges. Then used 4 /14" cron in side.
    I must say I was really blessed through the whole process. All of the snap lines might work out ok, and all of the braces might looked lined up, but you really won't know until you get the beams together and installed. The house is from the late 1800's and the room I did it in was a polygon, and one wall was sloped 45 degrees about 24" from the ceiling, which I then had to cover with the perimeter coffer.
    This was the first time I had done one, but I did not do this alone, the Lord was with me.
    Kevin
    Kevin
    "As a prisoner for the Lord, then, I urge you to live a life worthy of the calling you have received."
    Northern Virginia
    78
    It is all done out of walnut ply and walnut solid wood.
    Kevin
    Oct 2007
    Midlothian, Va
    72
    kevin,
    looks like a a high end job, can't wait to get one of these babies under my belt.
    brian
    Jul 2007
    Chicago 'burbs (more like the sticks)
    187
    I usually use veneer core plywood for backer, cheapest 'finish' plywood I can find. This ceiling was 3/4 Poplar, the crown was FJ Poplar, and the bolection molding was poplar.
    There is scarcely anything in the world that some man cannot make a little worse, and sell a little more cheaply. The person who buys on price alone is this man's lawful prey.
    Oct 2007
    Midlothian, Va
    72
    Tischler,
    Again Looks Fantastic, You Guys Are Excellent Craftsman, I Will Aspire To Live Up To These Creations.
    Again Keep Posting More Info On Useful Techniques, Do'd And Don't All Advice Is Helpful And Greatly Appreciated.
    Brian
    Come On The Irish!!!!!!!!
    Fresno, CA
    549
    Bosco-
    I used GK's method and employed MDF for beam sides and bottom. The method was awesome, made great time. Would problably not use MDF for the Beam bottom again unless cost mandated: When the light hits it I can see my nailing pattern slightly puckering out on the beam bottom. MDF is so dense that when you nail the end grain the material displaced by the nail has nowhere to go but out.
    That being said, I also wouldn't want to use cheap finger-joint, because it is never straight and would make installation a fight. Windsor one would be ideal for this application
    Northern Virginia
    78
    Quote Originally Posted by BOSCO1970 View Post
    Tischler,
    Brian
    I can't speak for the other guys, but the Lord was really with me when I did this. This is the first one I have ever done and am still amazed how it came out. I wouldn't call myself an "excellent craftsman," I still have a lot to learn.
    Kevin
    Oct 2004
    SF Bay Area
    1,338
    Not sure what the Katz method is, but on paint grade, I usually rip 2x to the appropriate width of the beams, GRKem (double layers) to the ceilng, then bevel cut all my MDF and glue up hinging with tape, then cross shoot with brads every 4" or so, let dry then trim and lift into position. I shoot the laser around the room first and make reference lines, (cheated where needed to make the final look right) and I short the beams height accordingly to the lowest part of the ceiling leaving gaps at the higher part of the ceiling. The gaps are then covered wth crown.
    Kye
    Nov 2007
    Brantford, Ontario, Canada
    1,477
    Just so you know how popular Gary is up here in Canada his book sells for $146.60 USED at Amazon.ca.... and they go up. http://www.amazon.ca/gp/offer-listin...070134&sr=8-25
    You have to wounder sometimes... I can't get a full quote on the Reassaue (SP is wrong I know) table and outfeed. OK I'm finished complaining... for now... wait till I go and dig out my car & truck... LOL
    One day I want to do a coffered ceiling I hope when I do it keeps up to not only my standards but all of yours.
    San Diego (Northern Mexico)
    3,976
    Quote Originally Posted by texastutt
    Damn, TT! That is plain old crazy! Are you sure the price doesn't include being delivered by Gary himself, and he gives you a 2 hour personal, one on one training session? :)
    Western suburbs of Chicago
    5,554
    Quote Originally Posted by texastutt View Post
    I'll be back shortly - when I return, the beer's on me. (Heads for the border with a passport in one hand & a stack of Gary's books in the other)...
    Greg
