Results 1 to 15 of 34
    Default The World's Greatest CHALKLINE?
    OK, it's time for me to treat myself to the best chalkline there is. Question is, what is it?
    I must have bought a few dozen of the standard Irwin aluminum reels in my lifetime. They are OK but the string that comes with them is too cheap and breaks easily. Then you lose the hook end.
    I've also had a couple of their geared plastic ones. Same problem.
    Recently I got my first Tajima reel from Amazon, and I'm completely underwhelmed. For $25 you'd expect something nice. The winding action is stiff and the hook requires you to make a very long mark in order to actually see it thru the hole in the middle. The line does seem nice, though.
    The guy I'm working with has a nice, old, geared, aluminum box. Can't remember where it came from, and probably had it 20 years.
    My concrete guy has another nice old one. Holds a ton of chalk. No name on it at all.
    Googling for "chalk line" doesn't turn up much, and there is zero for sale anywhere around here other than the Irwin stuff.
    I suspect that masons have the best chalk lines, and maybe I need to hunt down a masonry supply.
    Whatcha' know??
    Oct 2004
    SF Bay Area
    1,338
    Default Re: The World's Greatest CHALKLINE?
    Whatcha' know??
    I've got a couple of yellow metal ones that came with a tight braided line that doesnt fray or break, and holds chalk nice( a bit too much sometimes). Years ago I used to replace the line on chalkboxes with a gammon(sp?) line which worked well.
    Kye
    Chicago
    3,599
    There are a lot of different types out there with different features. I don't think there is a "best" chalk line. What type works best for you is going to depend on the type of work you do.
    The one I use for finish work is in the link below. The important features for me are the thin line (most lines are too fat for layout work where accuracy is critical), and the drywall pin.
    http://www.garrettwade.com/jump.jsp?...&itemID=105834
    Do a search and you can find past discussion, too.
    Apr 2007
    West Michigan
    134
    My last line that I picked up is a red Japenese line (drawing a blank right now). It has a fine braided line and wears a long time. The only thing I don't really care about it is it's only good for a couple snaps before rechalking and their is a lot of stretch to it. I'm sure there will be others mentioning the name, but i'll have to pull it out of my bag to remember it again.
    San Diego (Northern Mexico)
    3,976
    17 lb. braided fly line backing, in a Irwin Speedline is my favorite.
    Los Angeles, CA
    4,264
    I used braided fishing line as well in Irwin speed boxes, that no longer seem to be made. I bought a bunch when I discovered how much I like them. I do that with all good tools.
    Des Moines, Iowa
    3,895
    Dave
    I too had the same experience as as you.
    I am now using the Fat Max Extreme and am pleased with it
    http://www.amazon.com/Stanley-47-480.../dp/B000F99IHC
    Mark Parlee
    EDI Seminar Instructor
    970
    You guys that use braided fishing line, is there a certain brand you use? I tried it a few years ago with a black braided line and it wouldn't hold chalk.
    Geoff
    Upstream
    10,019
    Light green/white braided dacron trolling line, any brand, 15-20 lb. Leaves a razor thin line and breaks maybe every 2-3 years with heavy use. The 50 lb shown below is too heavy.
    Richie Poor
    Memphis, Tennessee
    2,763
    I have probably the last Irwin speedline w/ a metal case ever made, that was given to me to replace one that was broken when I loaned it on the job. I have no idea where the guy found it, but he did me a solid on it.
    I use braided dacron trolling line just like a few others. (Rick, the guy who showed me that trick was from your neck of the woods, must be something in the water up there. Here in Fla. we don't "fish lazy" like you Colo. hippies do)
    Paul
    970
    Thanks Rick, I'll give that a try.
    Geoff
    Same here. There's water around here, and guys with boats... must be a fishing store too.
    3,976
    For those of you searching for metal Speedline boxes, I saw a large sale display of them at our local Lowes yesterday. I've never noticed they were hard to find.
    Memphis, Tennessee
    2,763
    Are they "speed line" or just "strait line" Tom, I may have mis-spoke when I said speedline, but mine has the extra gearing to make it considerably faster than just the regular metal strait line.
    This link is to a metal Irwin chalk box, my "speedline" is the same thing except w/ the faster retrieve gearing.
    http://www.irwin.com/irwin/consumer/...e/64110_lg.jpg
    Paul
    Bergen County NJ
    1,966
    Paul,
    I have a few of those straight line's and they leak a little if you fill them to much like I tend to do. It just means that my pouch is a little red.
    i just got a Tajima CHALK-RITE Gear Drive i just filled it today i will let you know how it works out.
    -Sal
    -Sal
    ___________________________
    BSA Renovations
    www.BSA-Reno.com
