Results 1 to 15 of 19
    Clifton, NJ
    2,385
    Default Dense-shield vs Concrete board
    What would be best for shower walls (F/G pan) ? Have heard most of the +'s and -"s and still am not sure the best way to fly. Face peeling off D/S, water wicking up C/B. ??????
    SteveC
    970
    Default Re: Dense-shield vs Concrete board
    I like hardibacker screwed to the studs with a waterproof membrane over it.
    Geoff
    May 2006
    NJ
    5,832
    Steve,
    Hardibacker 1/2" also has my vote. I would also do a roll-on barrier as Geoff had mentioned. Seems to be one of the better products out there.
    Chuck
    midwest
    199
    any of them installed correctly work. Your right they all have +/-s. I like sheet membranes installed on them.That way I can skip tape ect. and dont have to mess with tring to get the fabric into the liquid...
    8,061
    Quote Originally Posted by inkster View Post
    Laticrete HydroBan does not require fabric at all.
    dg
    Los Angeles, CA
    4,264
    Properly installed Denshield with Kerdi Band on the seams and corners would be my vote. Just keep it off the pan by 1/4 inch as instructed and seal with Kerdi-Fix or your favorite poly caulk and to to town.
    Denshield is so much easier to work with than cement board. Seal the cut edges at the openings with Kerdi-Fix too.
    Properly installing Denshield means shimming the walls or notching the studs to the Denshield flows into the pan smoothly.
    315
    Wow, just kerdi the walls over any substrate, drywall or CBU and be done with it.
    Los Angeles, CA
    4,264
    Since you are going to be having to put up some kind of board anyway before Kerdi, my thinking is if the board is an effective water barrier (Denshield) why not use it an skip the step of the Kerdi? I am only talking about walls here. You still have to seam the joints and corners, so I feel more confident using Kerdi band here, rather than alkali resistant mesh tape and thin-set.
    I would even go one step further and spot the screw holes with Redguard or other similar product rather than the Silicone caulk as recommended by Denshield. Quicker dry times, less fumes and ability to bond to thin-st is my reasoning.
    On the floor use any standard Kerdi approach that works, Shower Kit, mortar bed, etc.
    Am I the only one who thinks the schluter system isn't the best?
    Jul 2005
    Florida
    368
    Quote Originally Posted by Kgphoto View Post
    Just curious what are you doing to back the denshield where it goes over the pan. Obviously you can't screw it, are you packing mortar up there when you do your bed..or something else?
    "You couldn't do it and they didn't help.."
    Quote Originally Posted by Taylord Home Improvements View Post
    Care to elaborate??
    midwest
    199
    Yes ,I think it ISN'T the best!
    Jul 2007
    Sioux Falls, SD
    28
    If it were my shower, I'd use the Kerdi Shower system from Schluter Systems. It is the least labor intensive means to do a shower. When done properly, it will stand up just as well as any other system. It also eliminates a lot of potential for mold growth.
    Brooklyn, Fire Island
    5,436
    Care to elaborate further?
    Nothern California
    734
    What do you think IS the best? (I would genuinely like to know.)
