Results 1 to 6 of 6
    Dedham, MA
    345
    Default Proper insulation and sheathing in a breezeway/3 season porch
    The home is a Cape, looking at it from the street the 1 car garage is on the left, then breezeway then the house. The exterior siding of the house is visible on the inside walls of the breezeway. My question is this:
    Where the garage is unheated and the breezeway is to be insulated, what is the proper way to finish the wall between the garage and the renovated space? Can it be drywall both sides with insulation in the bays, or would the inside of the garage wall need to be an exterior finish?
    -Sean
    San Diego (Northern Mexico)
    3,976
    Default Re: Proper insulation and sheathing in a breezeway/3 season porch
    Drywall should be fine, as the inside of the garage wouldn't be exposed to the weather.
    May 2007
    right around the corner
    1,609
    i agree with tom, u can also caulk the stds to the drywall on the backside of the garage wall to help stop air infiltration incase a seam in the drywall has pock holes or is not finished at the base on the inside of the garage. overkill I know, but it won't hurt
    JASON
    George S. Patton
    NOLA
    4,360
    Look at DensArmor Plus for the garage side.
    Is the b-way heated?
    Bill R
    Feb 2007
    Wisconsin
    578
    Id use fire board on the garage side, it may be code for you anyhow, it is here.
    Dedham, MA
    345
    It is heated, just a strip of electric baseboard.
    Fire board is a good point. I'll check that.
    -Sean
