Results 1 to 15 of 33
    New Jersey
    315
    Default How often should breakers be changed ?
    Most homeowners believe that once they move into their homes and as long as they had a home inspection where the electrical system passed they are completely safe. I had a situation just yesterday doing a bathroom remodel where I had to shut off a circuit in order to work on it. I inadvertantly shorted the branch circuit feed to the side of the metal electrical box (PLEASE DON'T TRY THIS AT HOME BOYS AND GIRLS !!!) and the breaker took about 2 seconds to trip. Upon further investigation I found the breakers were the Square D QO type (probably one of the best breakers on the market) but also probably haven't been changed out since their original installation some 25-30 years ago. Does anyone know what the expected life is of circuit breakers in general and how often they should be changed out ?
    North Carolina
    2,240
    Default Re: How often should breakers be changed ?
    An advantage that I have over a lot of my fellow electricians throughout the nation is I have a lab at my disposal. I do all kinds of experiments in lab to let students see just what takes place in an electrical circuit.
    We take an Edison base fuse, a time delay (type S) fuse and a breaker all of the 15 amp rating and load them with a variable resistor to the point that they open.
    Wonder which opened first?
    Wonder which opened last?
    One of the things that I find truly amusing is the electrician that will sell a service upgrade from fuses to breakers and use the selling point that the breakers are safer than the fuses. Nothing more is done to the electrical system other than the service change. The homeowner now thinks that their home is safer because they had their house rewired by this electrician.
    The homeowner still has the same number of circuits supplying the same conductors that are connected to the same devices that are just as old as the fuses were. The difference is the homeowner now has overcurrent that has a trip curve 4 to 6 times of that of the original overcurrent.
    This type of service upgrade is like taking the old maid that lives down the street to a beauty parlor and having her hair, face and cloths all made up to look real pretty. When she walks out she looks a lot different but on the inside she is still the same old maid that lives down the street.
    Upstream
    10,019
    Mike,
    Nice story about a fuses-to-breakers service change. Still, you haven't directly answered Phil's question. I am also curious if changing aging breakers is a maintenance issue or a waste of time and money.
    Richie Poor
    North Carolina
    2,240
    I was addressing the
    Quote Originally Posted by goldstar View Post
    part of his post. Sorry I should have qouted that part in my post.
    Upstream
    10,019
    And then he asked...
    ...to which there was also no reply...
    Richie Poor
    492
    Quote Originally Posted by jwelectric View Post
    I was addressing the part of his post. Sorry I should have qouted that part in my post.
    But your test has nothing to do with this situation.
    Sounds like the magnetic coil was defective.
    "Standard" breakers have a dual trip system. A time inverse bimetalic trip with a heater. That is for overloads. And a magnetic coil for fast trips on high current faults.
    SQ D has the trip curves posted on thier website. But takes some searching to find.
    North Carolina
    2,240
    Oh yes, the answer is in the post if you know how to find it.
    If I was going to worry about my electrical system needing attention I would worry about it as a whole instead of in parts.
    Unless there is evidence of something failing or unless I am working the breaker a lot then it would not need replacing at a certain point in time.
    Quote Originally Posted by BillHartmann View Post
    I would tend to agree with you if it wasn’t for the fact that the overcurrent devices are chosen at random.
    The key here is the words “high current faults” and we are loading the overcurrent devices with a variable resistor where the load is increased slowly.
    The Edison base fuse will blow at or close to the 15 amp mark but I have saw several 15 amp breakers of different makes hold for several seconds at over 20 amps.
    Upstream
    10,019
    Well I don't know how to find it. Too cryptic for me. Simple question, simple answer. Anyone?
    Richie Poor
    Apr 2007
    N.M.
    261
    As Denzel said "explain this to me like I'm a 3 yr old", 'cause I am missin' something. I too am curious how long the life is....
    -Don-
    Silence is golden...duct tape is silver ;-)
    http://rioranchosremodeler.com/
    North Carolina
    2,240
    Quote Originally Posted by Diamond Custom Homes View Post
    Until they break
    Oct 2006
    Central PA
    314
    Circuit breakers don't get better with age. I find more failed breakers in damp basements, unconditioned outbuildings, and outdoor panels then I do in dry indoor panels. Circuit breakers rarely fail, and the 2 seconds you quoted can be within tolerance. I would never encourage wholesale replacement of circuit breakers at a certain time interval, unless certain environmental conditions prevailed. In that case, the panel and the breakers may well need changing at the same time. Horse and cow barns are one such example.
    I agree that fuse protection is superior to breaker protection. It is for this reason that the MDP's of large commercial services often utilize fuses. You can get a "boutique" fuse with a fairly customized trip curve more easily than you can get a breaker to provide the same protection. To advocate fuses for residential services, while certainly meritorious from a technical standpoint, would be tantamount to business suicide.
    -Marc.
    Brooklyn, Fire Island
    5,421
    I'm confused. Why don't they just make breakers with a trip curve similar to a fuse's?
    Oct 2006
    Central PA
    314
    Quote Originally Posted by frenchie View Post
    Then you're into an electronic breaker, and that would be prohibitively expensive for a resi panel.
    -Marc.
    New Jersey
    315
    Quote Originally Posted by mdshunk
    There's no question that fuses will give you a faster response and better protection. However, your last sentence says it all in a nut shell. People old enough to have had fuse panels in the past would feel as though they were going backwards in time not to mention that replacement fuses aren't always kept readily available. It's much simpler to just reset the breaker irrespective of the trip curve.
    Good point.
    I believe the vast majority of breakers on the market today are the "quick-open" type.
    Another good point. If the breakers are corroded chances the buss bar and connections inside the breaker panel are also corroded.
    New Jersey
    315
    Contrary to popular belief most of us are out there to make money. Selling a fused disconnect is a tough sell.
    Please tell me you're not out there selling people fuse panels !! If you are, please don't admit it in open forum. You'll embarrass all of us who think so highly of you.
