05-15-2007, 09:18 PM #1
- Oak Park, Illinois
- 463
What's the latest you're using for a shower ceiling?
Wondering what everybody is using lately, as I am leary of 5/8" greenboard, and not really sure if code compliant.
I will ask the inspector at framing inspection time, but wanted to gather some info.
I searched, but not much as of this year.
RJCEvery job is a self-portrait of the person who did it. Autograph your work with quality.
05-15-2007, 09:33 PM #2
- Dec 2005
- Portland, ME
- 970
Re: What's the latest you're using for a shower ceiling?
I now use purple board. I think its National Gypsum xp or something like that.
Geoff
05-15-2007, 10:06 PM #3
- Bergen County, NJ
- 4,410
GP DensArmor Plus.
You will need to skim it with setting compound, but it's bombproof.
05-16-2007, 04:34 AM #4
- Dec 2005
- Portland, ME
- 970
I use the densarmor for shower walls and purple board for the rest of the bathroom because its smoother. I usually do the whole ceiling with the purple board.
Geoff
05-16-2007, 08:26 AM #5
- Feb 2006
- Southern NH, north of tax-achussetts
- 2,078
Green board is only to be used 12" oc per USG on ceilings, green board is starting to be phased out in alot of places around here. At HD here in NH green board is about .50 cents more per sheet than DAP. National Gyp. XP is more than enough in an above grade bathroom on walls and ceilings IMO. GP Dens Armor Plus would a wise choice for any basement and an upgrade in a bathroom, remember it needs to be skimmed so there is extra labor.
Greg-
Could you use DAP as a tile backer around a tub/shower?"cheap labor pays for expensive headaches"
05-16-2007, 12:12 PM #6
- Bergen County, NJ
- 4,410
05-16-2007, 12:39 PM #7
- Feb 2005
- Walnut Creek CA.
- 208
US Gypsum Greenboard
Originally Posted by US Gypsum's Website
RMc____
05-16-2007, 02:22 PM #8
- Feb 2006
- 2,078
I'm not type of guy that would half ass anything I do, nor would I go over board which is why I asked the question. I have seen a alot of green board used as a tile backer which is half ass. But I know DAP is pretty tough stuff didn't know if it was a accetable alturnative to durorock or hardi-board.
05-16-2007, 08:24 PM #9
- Bergen County, NJ
- 4,410
05-17-2007, 05:07 AM #10
- Mar 2007
- NH Seacoast
- 143
MR board (green board) was originally made as a tile backer.
MikefromNH is correct when he stated that USG does not recommend its use on ceilings unless framed at least 12"oc.
More important than the use of MR board is the type of paint used and proper ventilation.
My guess is that they make a type X 5/8 MR board that does have a half hour burn time and is code compliant. I'll make a call this morning to affirm.Last edited by Mike Gill; 05-17-2007 at 05:29 AM.
05-17-2007, 06:55 AM #11
- Mar 2007
- NH Seacoast
- 143
RJ,
Type X, 5/8 MR board with a half hour burn time is available.
05-17-2007, 10:03 AM #12
- Los Angeles, CA
- 4,264
USG no longer approves Green Board as a backer for tile in wet areas.
IF you cover it with a surface applied membrane, Kerdi, Redguard, etc., then it will still work. Ceiling framing needs to be 12 inches on center.
However, if you are using a surface applied membrane, you don't need green board so save your money.
05-17-2007, 01:12 PM #13
- May 2007
- Sunny san jose, where mud dries on time!
- 8
Wow this is all a little confusing to me. Im a quality taper in the bay area, sunny california and code here calls for greenboard in shower areas.Then the tile guys apply a hardy back over our rock and then tile. Ceilings get regular rock. Must be because of the climate difference. If i were u i would get advice from someone in your area.
05-17-2007, 07:49 PM #14
- 463
Met with the framing inspector today, and showed him in our drywall stack the 5/8" fire code, green board, and he said it was fine to use on the shower ceiling.
I then asked him about the "purple" xp board, and he looked at me as if I was from Mars!
So, I guess I will use it, tape it with a setting compound, and caution my clients painter to use an appropriate product for priming and finish coats.
Thanks for your replies,
05-18-2007, 10:18 PM #15
- Los Angeles, CA
- 4,264
Taper4life,
While Code, which hasn't been updated in years still allows greenboard in its prescriptive section, it also has a notation that says if there are two parts of the code in conflict, the most restrictive governs. There is a code section that prohibits using materials not consistent with the manufacturers guidelines.
So while code is lagging behind, you would do a better job, not using green board as there are other, better options available.
