Results 1 to 12 of 12
Thread: Wavy Shingles
    Apr 2007
    Connecticut
    6
    Default Wavy Shingles
    Hi every one.
    I have a siding job where I have to install 18” cedar shingles with wavy pattern at the gable end. I am thinking of laying the shingles on the ground drawing my pattern over them cutting the pattern with band saw and then installing them in sequence. Any one has a better idea?
    Coventry, RI
    10
    Default Re: Wavy Shingles
    Perso, you may want to add who you are, where and what you do to your profile. People like to know who you are.
    Ron
    Keep it simple, stupid.
    Little River, SC
    1,234
    Check the cedar shingle bureau web site.
    http://renov8u2.com
    Jan 2006
    Southwestern Vermont
    1,972
    I've never done it so I can't help you on the technique but click the "research" tab above and type "cedar shingle patterns" in the search box. A bunch of JLC articles come up that might help.
    -Norm
    essex mass.
    162
    can you cut with a router after install with a pattern bit
    Feb 2007
    Portland Maine
    434
    Unless you have a really tight radius you probably don't need to cut the radius into the individual shingles.
    It's more a matter of tapering the shingles so you can run the pattern
    Do you have any more details- or a sketch of what you are trying to achieve
    Quote Originally Posted by Perso Builder View Post
    Hi every one.
    I've done exactly as you describe. Lay the shingles on the bench with the butts aligned. Use a straightedge to draw a line right across all of them, up where it will be covered--you use this line to re-align them on the wall. Number them in order, so you can nail them up in order. Draw your pattern, cut them with a jigsaw, then nail them up. It may be helpful to clamp them to the bench with a long board and some clamps while drawing the pattern.
    There's some of this on one wall of my house... I could shoot a pic tomorrow. Did it as an experiment, just for fun, but didn't do enough for real effect.
    Apr 2007
    Connecticut
    6
    David M.
    Thanks for the tip on drawing the line. I probably need this line to keep the reveal for each shingle the same. What did you use as your template to draw the wavy line? A picture would be nice if it is easy enough.
    Here's a photo. On the first couple areas I did I spent the time to draw a wavy line and then cut it with the jigsaw. After about twice like that I just cut it freehand with no line. If I were doing a LOT of this I would probably just cut a whole sh!tload of shingles with curved butts, take them to the wall, and then compose the curves on the fly by nailing them up to make them look good. When you have courses above that also have curves you need to make them work together. A guy with a few hundred shingles precut could work quickly and make it look good.
    If you search the web you might find some photos by a guy named Roger "Crash" Dumas. Lots of shingle art...
    Old Orchard Beach, ME
    114
    There is an awesome shingled building in Kennebunk, Maine. All three visible sides of the builing are shingled in a way that gives the impression of a three dimensional image. I should be down there soon, I will try to take pictures. I love that place!
    Dustin
    Apr 2007
    Connecticut
    6
    Dave M.
    That is it. I have to do two gable ends with wavy patterns. The patterns are shown regular on the print and run the whole length of the gable for few curses of shingles. I will develop the pattern get it approved and cut and number them and then send them up there to be nailed.
    9,252
    Here's another photo of some wavy shingles...
