04-20-2007, 07:51 AM #1
- Walnut, IL 61376
- 114
Circ. Saw Blade for Radius Cutting
Who makes a 7 1/4 Blade for cutting radius, and where can I buy one ? Need them asap.
Keith
04-20-2007, 08:08 AM #2
- Port Orchard, WA
- 2,601
Re: Circ. Saw Blade for Radius Cutting
04-20-2007, 10:47 AM #3
- Mar 2006
- Southeast Michigan
- 28
04-21-2007, 08:28 AM #4
- Jan 2006
- Houston,Texas
- 641
I use a 24 tooth dewalt framing blade. Depending on the thickness of the wood and the tightness of the radius, sometimes I make one cut at half depth then come from the opposite direction at full depth. Try not to let the blade hang more than a 16th below the board. A cut board comes in handy, too.
Over time, cutting radii will warp the insides of the saw and the blade will wobble, so I'd recommend using an older saw.
john
04-21-2007, 04:37 PM #5
- woodstock GA
- 5,795
Kreg
www.builtinking.com
04-25-2007, 12:53 AM #6
- Sep 2006
- Sydney Australia
- 214
I have never seen these blades in Australia.
We have a job this week end to cut some long flowing curves plan was to use router but a saw would speed this up. Can a standard 24t blade be used. would a festool saw work better than a standard saw.
04-26-2007, 06:08 PM #7
- Walnut, IL 61376
- 114
Tim, I ordered the blade, but they will not work on my worm drives. Which saw are you using. They recommended Makita or Milwaukee.
Keith
04-26-2007, 08:05 PM #8
- Port Orchard, WA
- 2,601
This is a bit of a problem. They sell two blades, one for left side and one for right side. They gave me a right side and we tried to get it on the Ridgid, but it won't fit without really forcing it.
I need to take pics to send them. I'm supposed to see which saws it fits on and it seems like the saws with the "anti-snag" guards it doesn't fit as well.
I bought one blade awhile ago and put it on the Skil Mag77 and it seemed to work ok, then I found out it was supposed to be for blade right saws. http://pic40.picturetrail.com/VOL293.../222524226.jpg
So this weekend I'll try and see which saws it fits/doesn't fit and take some pictures. I've been super busy in April so I'm behind on a lot of stuff and need to catch up. Got a busy summer ahead (seeing John Mayer live, John Butler Trio and Dave Matthews band and cannot wait) in between frames, siding and I get to do some trim hopefully :-)
I'll try to get that all done and posted.
04-27-2007, 08:11 PM #9
- Jan 2006
- Houston,Texas
- 641
I'm not a big fan of the arcus blades.
I like a regular one. I just remembered getting one of those "progressive" blades from tenryu that had a combination of different teeth, like 1/4 40 tooth blade 1/4 24 tooth blade 1/4 16 tooth and I forget what else.... anyway, that is a good radius cutting blade.
I believe porter cable has a "lazer" blade like that, it's worth a try.
If anyone wants a slightly used blade right arcus, I'll pass it along. It's sitting in my truck collecting dust. You can try it out without buying one.
John
04-28-2007, 01:47 AM #10
- Sep 2006
- Sydney Australia
- 214
We ended up using 12 tooth festool blade on ts55. to do a series of free flowing curves in 1 in hardwood flooring on 1 in ply.
will post pics
04-28-2007, 04:04 PM #11
- Los Angeles, CA
- 4,264
Mark Currie in his framing book recommends just a standard blade for radius cuts that are not too tight.
