Results 1 to 15 of 19
    Feb 2007
    Philadelphia, Pa.
    1,510
    Default What's the best whole house generator?
    I've installed 2 generators in the past, but never one this big.
    The home has 2 200 amp panels with a total of 32 circuits and the home has natural gas.
    My question has 2 parts.
    Which generator would you recommend?
    Which transfer switch?
    I've looked online and found a generac 60,000kw for 13000.00 and a 400 amp transfer for 1800.00.
    I've had little experience with installing these larger units and would like to hear everyone's thoughts before I purchase.
    Has anyone had problems with these particular units?
    -Dennis
    Feb 2007
    Baltimore, MD
    86
    Default Re: What's the best whole house generator?
    I would check with the manufacturer to see what they recomend. Are you trying to power the entire house? Also, check the gas service to ensure it will be able to deliver enough for the generator-this can be a problem.
    John from Baltimore
    "One Day at a Time"
    The bitterness of poor quality lingers long after the sweetness of low cost is forgotten!
    Oct 2005
    328
    I would use a 100 amp sub panel with a 100 amp transfer switch for "necessary"circuits:lights,heat,some cooling,kitchen,tv, security.Probably 15kva generator.
    Bob O.Eighty Four,Pa.15330
    Feb 2007
    Philadelphia, Pa.
    1,510
    yes I'm trying to power the whole house, and I will have my plumber check the gas consumption versus feed (I never even thought of that).
    I tried to sell the 100 amp, but they just weren't biting.
    Calling the manuf. has always been hit or miss for me, here I can trust peoples opinion because there is no bias.
    -Dennis
    Yorba Linda, CA
    414
    Caterpillar generators are very highly regarded. They're a whole 'nother class up from normal residential generators - and priced accordingly.
    But perhaps only the best will do...
    http://www.cat.com/cda/layout?m=37508&x=7
    New Jersey
    315
    Quote Originally Posted by WarriorWithWood
    They'll probably stop biting when they find out how big and how expensive the unit they believe they want really is, and how much it will cost them to have you install it. If you're looking at a unit that delivers say 150KW, the cost will be around $25K plus a 400 amp Xfer switch that will cost you around $2K. Now you have to pour a concrete pad that will hold this thing and then hire a crane to drop it onto the pad because it weighs about 2500 lbs (you can't move this around with a hand truck). Now you and the plumber have to come in to work your magic so that your customer can watch the Superbowl when the power goes out !!!
    Believe me, they're just making you spin your wheels because they don't realize what it takes to have something like this installed at a residence. Go ahead and give them a price for the big unit but in reality, don't expect to install it. Have your price ready for the one you recommend. If you go to the Northern Tool web site you'll find a 16 KW Guardian unit with a 100 amp, 16 circuit ATS for about $3.6K. This unit will start a 5 ton AC unit. I know you've probably done this already but you have to explain to your potential customer that this generator is to be used for a back-up only during power outages. You don't need to run your double wall oven, microwave, dishwasher, electric dryer, 3 AC units and your welder in the garage all at the same time during a power failure.
    I believe you'll have a better chance of selling a 16 KW unit (or similar unit) than one that will power the whole neighborhood. Take the advice from the others here. Make sure you have a big enough NG service to run this unit.
    Just my opinion.
    Feb 2007
    Philadelphia, Pa.
    1,510
    Well 35k to them is really no big deal for their "peace of mind" considering they spent 2mil on this house.
    I'll let you know what they say when I give them the number.
    Thanks for the info guys, it looks like either Cat or Generac.
    I was even thinking of 2 smaller generators (150 amps for each panel) might be a better (cost effective) idea, but then I believe noise can be an issue.
    I will let you guys know how I make out.
    -Dennis
    Apr 2006
    NYC
    38
    will they accept a diesel unit? A good 45kw unit with a cummins or perkins engine, soundproof enclosure and 100 gal belly tank can be had for around $20k. At full load consumption is around 3-4 gal/hour.
    I've installed a number of propane gens. Never really liked the big gas burners.
    Oct 2006
    Central PA
    314
    When you're up to that size of a genset or larger, I only install Cat. Smaller one's, for me, it's a toss up between Kohler and Onan.
    -Marc.
    581
    Unless they expect the power to be off often, going to a hotel is the better choice.
    Oct 2006
    Central PA
    314
    Quote Originally Posted by George Roberts View Post
    Ha! Right....
    About once a year, the wife and I will get a hotel room on the other side of town for no reason at all. Sorta nice.
    -Marc.
    Georgia
    1,832
    Oh, I'll bet you've got a reason... ;-)
    Feb 2007
    Philadelphia, Pa.
    1,510
    yeah they have 3 kids, all under 5. Need I say more:-(
    -Dennis
    May 2006
    Charlottesville, VA
    18
    Here is some commercial-free info on residential stand-by generators:
    http://www.toolbase.org/TechInventor...ntDetailID=671
    Georgia
    1,832
    Quote Originally Posted by 78_GMU View Post
    I don't see any generator info there, just battery systems.
