Results 1 to 5 of 5
    Virginia Beach, VA
    14
    Default removing heavily textured plaster from drywall ceiling
    I am remodeling a home with heavily textured plaster over drywall ceilings in two rooms. I need a smooth ceiling. What is the best way to accomplish this? I also need to remove a very large round ceiling medallion, also plaster. Sanding does not seem to be an option, as the plaster is quite hard and the texture very coarse. I have contemplated removing the ceiling and replacing the drywall, but this seems extreme. Thanks in advance.
    Chris G.
    Virginia Beach, VA
    Meadow Vista, CA
    2,110
    Default Re: removing heavily textured plaster from drywall ceiling
    Use a 1 1/2 putty knife as a chisel with a hammer to remove the medallion. Float the ceiling.
    May 2006
    Miami, FL
    1,155
    This has been discussed so much around here. The best way to do it is to apply a think layer of mud with a 10 or 12 inch knife, and fill out the entire ceiling. Then repeat this process 2 more times, and you should be happy. Sanding is not going to remove it, and scraping it off with a chisel will only make you go back and touch up the ceiling anyways.
    My other solution, screw in some 1/4" or 1/2" drywall in the ceiling and refinish smooth.
    Virginia Beach, VA
    14
    Thanks for the reply. I want to add a fair amount of recessed lighting, and have decided to demo the ceiling a replace the drywall. All rooms will have crown moulding, reducing the mudding labor.
    Chris G.
    Virginia Beach, VA
    May 2006
    Miami, FL
    1,155
    Yea I think thats the best choice, its the easiest. In about no more than 2 hours you can demo and clean up the mess, verses spending all that time.
