Thread: Degrees to Pitch conversion
10-29-2006, 02:56 AM #1
- Jun 2005
- 14
Does anyone know the math formula to convert the angle of a roof in degrees to X in 12 pitch?
10-29-2006, 05:24 AM #2
- North Jersey
- 229
Re: Degrees to Pitch conversion
If you have a construction master calculator it will do it for you. If not PM me and I'll do it on the calc.
10-29-2006, 05:50 AM #3
- Westchester,NY
- 53
Divide the rise by the run and take inverse tangent of that and it will spit out the degrees.
Kris M.
10-29-2006, 06:45 AM #4
- Caldwell, NJ
- 3,153
Barry,
Using a Scientic calculator or Construction Master Calculator. Press the Tan button for any given degree on the plans and multiply by 12 and that will be your pitch.
A Construction Calculator is the easiest one to use.
If you were given a 22.62° pitch on a set of plans, you can this.
22.62 [Pitch] [Pitch] Returns -5 (5/12 is your pitch)
If you have a scientific calculator you can do this.
22.62 [Tan] x 12 = 5 (5/12 is your pitch)
45 [Tan] x 12 = 12 (12/12 is your pitch)Joe Carola
10-29-2006, 06:47 AM #5
- Caldwell, NJ
- 3,153
10-29-2006, 07:20 AM #6
- Little River, SC
- 1,234
You could just look on the speed square. The pitches & angles are listed on the square & in the book that comes with it.
http://renov8u2.com
10-29-2006, 09:21 AM #7
- Oakhurst, CA (near Yosemite Natl Park)
- 1,562
this is handy
www.telianconstruction.com
10-29-2006, 10:29 AM #8
- Caldwell, NJ
- 3,153
Barry, What are you using to figure your rafters now?
Are you using a Scientific Calc, Construction Master Calc, Framing Square?Joe Carola
10-29-2006, 10:56 AM #9
- Caldwell, NJ
- 3,153
Barry,
Just to give you an example of how you can use Construction Master Trig Calculator.
If you were give a pitch of 22.62° on a set of plans and your common rafter run was 16’ for example without a ridge deduction, you can do this:
Using a Construction Master with Trig:
22.62 [Pitch]
16 [Feet] [Run]
[Diagonal] = 17’ 4” (Common Rafter Length)
Or you can do this:
16 [Feet] [÷] 22.62 [Cosine] = 17’4” (Common Rafter Length)Joe Carola
10-31-2006, 03:00 AM #10
- Jun 2005
- 14
Thanks Everyone, I do remodel projects and run into some oddball pitches so I use a Stabilla electronic level which give me the degrees. I've used the speed square to convert to pitch, but if the roof is an oddball, I need to guess at the pitch (sometimes I need to hit an existing height). I use the step-off method to layout rafters.
11-06-2006, 05:14 PM #11
- Nov 2006
- 19
Perhaps this print out will help?
Best of luck,
11-07-2006, 11:19 AM #12
- Mar 2005
- Sol III
- 1,935
Barry, if you are given only the measurement in degrees, since the tangent of an angle is the rise/run you can use this series to solve for Tangent of an Angle.
Be sure you multiply the value of the angle (x in the formula) in degrees by pi/180 to convert it to radians before substituting.
It's a good formula to know if you don't have a calculator but keep a box of pencils and a ream of paper handy ...
EDIT: You asked for the "Over 12" value, so after you are done cyphering multiply the result returned by the tangent formula by 12.
Originally Posted by Barry Dennis
"I cannot teach anyone anything; I can only make them think." - Socrates
11-08-2006, 03:31 AM #13
- Oct 2005
- off the coast of new england
- 412
Curtis , welcome to the fold
11-08-2006, 04:32 AM #14
- Mid Hudson Valley
- 314
Call me Old School, but why not just use a square to begin with? if the slope is 5 3/16 on 11 who cares, measure the run off your square and make pitch blocks to set your saws if need be. It doesn't need batteries and it is always right.
11-08-2006, 09:42 AM #15
- Feb 2006
- San Diego (Northern Mexico)
- 3,976
Good info. but I still haven't figured out why it's on the Estimating & Mark-up forum.
