Thread: Framing for a jacuzzi
10-26-2006, 07:18 PM #1
- May 2006
- Miami, FL
- 1,155
I'm a drywall guy, but have a job to frame a jacuzzi, and was wondering if all I got to do is lay some 1 inch 5/8 track and stud, then lay the jucuzzi on top of the tracks. Or do I have to had something else under the jucuzzi. Its a straight box, and I know I got to frame the tracks and studs like an inch in from the edge of the jacuzzi. (1/2 dryall, and 1/2 for tile).
Does the jacuzzi usually lay on top of the track?
10-27-2006, 06:19 AM #2
- Branford, CT 06405
- 3,453
Re: Framing for a jacuzzi
"Does the jacuzzi usually lay on top of the track?"
No, unless they do something different in Florida. Besides the fact no one knows what brand, how big, etc...
Read the mfg installation instructions, then call then to make sure you provide the proper framing for the future tilework.Take Care
10-27-2006, 08:00 AM #3
- Oct 2006
- Henderson, Nevada
- 61
Don't forget the access door!
Milburn
10-28-2006, 07:40 AM #4
- Maywood, New Jersey
- 36
Like James mentioned. You should follow the mfg instructions. All tubs are different. Most tubs I've worked with must be set in some sort of base material. They also will provide you the template for the hole to cut out in the deck.
Common sense is a gift from God that cannot be taught.
10-30-2006, 05:36 PM #5
- May 2006
- Miami, FL
- 1,155
Thats the problem, no mfg instructions. It looks very simular to this- http://www.terrylove.com/jet.htm
So once I frame the tracks and the studs, my question is if its neccessary to put a sheet of plywood on top of the track, then drop it, or just drop it on the track.
10-30-2006, 08:03 PM #6
- 36
I would put plywood on followed by durok, wonderboard or hardibacker. Also, I'll make some 1/2 spacers (scraps of plywood that would be 3/8 tile and 1/8 for thinset), put the spacers around the perimeter of the hole, Lay some structolite on the floor and press the tub into the structolite. The tub should NOT rely on the rim to hold it up.
10-31-2006, 09:50 AM #7
- Feb 2005
- Walnut Creek CA.
- 205
Many tub manufacturers specifically say, DO NOT SUPPORT TUB by tile deck.
Others want a mortar bed set, & the current tub I am dealing with (jacuzzi) has four little chinzy foam pads as feet. Set on level surface is all they want.
Originally Posted by jacuzzi website
RMc____
11-01-2006, 06:32 PM #8
- Jul 2006
- Florence, Alabama
- 60
Erik R said it... tub should NOT hang on frame .. flange will break. Shim under the tub. I build my frames 3/4" higher than needed and then just slide a piece of 3/4 plywood underneath.
And as for ply on top.... only if the tub is oval.
Over & Out
11-02-2006, 10:38 PM #9
- Mar 2005
- Mt Prospect, IL
- 532
Ditto on the Structolite. I've done topping cement and thinset mortar beds under tubs, but I think it's less mess with the structolite.
This one was a rare situation - I had on bath that was framed way to tight, as I found out on a test fit.
Instead of worrying about mix setting up while fitting and leveling, I made a dam around where the tub would sit, set the tub, and then poured a bucket of Jiffset (had access through the front skirt)Robert
DUE TO CURRENT FINANCIAL RESTRAINTS, THE LIGHT AT THE END OF THE TUNNEL WILL BE TURNED OFF UNTIL FURTHER NOTICE…..
11-04-2006, 10:59 AM #10
- Mar 2006
- Vermont
- 12
What is structolite? I usually use mortar mix but would love to know about a better option.
11-04-2006, 03:08 PM #11
- 36
Structolite is a very lightweight brown coating. If ya have ever seen plaster walls its similair to the stuff oozing through the lath strips. I also use it for when I need to fill heavy voids in walls. Its very light and fills really well.
Heres a link for ya.
http://www.usg.com/navigate.do?resou...aq.html#N2015DCommon sense is a gift from God that cannot be taught.
11-06-2006, 03:53 PM #12
- May 2006
- Miami, FL
- 1,155
Hey guys, to keep you updated, I framed it out today like I explained, and the tub fits perfectly. It does sit on the deck, so maybe I might add some support under the tub like stated here. I'm thinking I let the tub also sit on some 2x4s and shims.
11-06-2006, 04:06 PM #13
- May 2006
- Miami, FL
- 1,155
11-06-2006, 04:18 PM #14
- Va.
- 3,675
