This will probably be a very basic question compared to others posted here, but I could really use some help.
I'm starting to hang drywall in my newly finished basement, and Mr. Ferguson's book has certainly helped. But I'm still having a few problems with corners and out of square edges.
My studs are 16 o.c. and sqaure has far as I know. However, some of the beveled joints won't line up square without trimming. Second, I'm trying to preserve as many beveled factory edges as possible, but getting everything to line up with wihout cutting is really difficult, especially in corners.
For example, the last sheet of the wall that buts against a corner was out of square with the factory joints. A problem with the corner or something else? Why is this happening? Do I need to change my technique?
Second, what is an acceptable gap between the sheets in corners?
Third, does anyone have any tips on scribing the sheets?
Thanks for any help or advice! I'm on the verge on hiring this out because I want a nice installation for my taping contractor. On the flip side, I'm really intersted in learning this and would like to do it myself.
Thanks!
Patrick
Side note: These sheets are hung vertically, because I can only get 8' sheets into my basement. I'm willing to switch to horizontal if that will fix my problems. Can I leave the four sheets that are in place and switch?
Thanks!
Patrick
