Results 1 to 5 of 5
    farther from Metro Detroit(not quite shitsville, USA)
    197
    Default Screen-Tight Porch Screening??
    I am about to start a small project involving screening in a client's porch. Has anyone used or heard of the Screen-Tight system that uses the vinyl bases and caps to allow for splining??? Any advice or insight would be much appreciated.
    I found an article here about it, http://www.jlconline.com/cgi-local/v...177f00000105a2
    it says it is great, but I have never actually heard of anyone using it.
    Massachusetts
    86
    Default Re: Screen-Tight Porch Screening??
    We screened in a porch a few years ago using Screen Tight. What, specifically, are you worried about? Our take is that it's:
    1. More expensive than an "all wood" solution
    2. Similar labor
    3. Easier to create a smooth, tight screen
    But the biggest benefit is that screening can be replaced more easily.
    Hope this helps,
    Wayne.
    197
    Thanks for the reply -- I am not really worried about anything, I just have never used this product or even seen it used for that matter and I wanted to make sure it wasn't some cheap gimmick. Just wanted some insight.
    While I'm at it, have you ever installed any Zanzar Retractable Screen Doors?
    Branford, CT 06405
    3,677
    I used the ScreenTite system for a large screen porch and was impressed. I will use it again because it's easy to get screens that look super and no sags!
    Take Care
    47
    We currently use the Screen-Tight system on our screened in porch upgrades for our homes. We currently build around 150 units now with plans to jump up to 200+ next year. Out of all of these units, about half used screened in porches. We have been pleased with the Screen-Tight system and going forward, we have no plans in changing to another screening setup.
