Results 1 to 15 of 34
    Mar 2005
    Illinois
    138
    Default T&G Carsiding in Sunroom
    Hi all,
    I'm building a sunroom (for myself) this fall and was considering 6" or 8" T&G carsiding for a ceiling finish in the sunroom. I've only installed carsiding a couple times in the past.
    My question is, is it common to face nail this size carsiding if you are not painting it? I like the look of unfinished pine but I'm not sure if it should be face nailed (in the field) or not. Also, the rafters are on 24" centers...is it fine just to nail or would anyone suggest glue as well?
    On the other two jobs we pretty much toe-nailed the carsiding through the tongue and didn't have any face nails. It didn't seem like the best method to me at the time, but that's what we did.
    Jul 2005
    Dutchess county NY
    675
    Default Re: T&G Carsiding in Sunroom
    what is car siding?
    Houston & Washington Texas
    12,272
    Also known as 117 siding. It's kind of a teardrop pattern, I believe 1x8.
    Ruch, OR
    2,414
    I still don't know what it looks like!
    If it's T&G, I'd normally install it with the tongue out and blindnailed. There's nothing wrong with toenailing t&g. I hate face nails.
    Gary
    Chicago
    3,599
    Also known as drop siding, very common on old sheds, etc. in the midwest. Think beadboard with a bevel instead of a bead, and applied horizontally instead of vertically.
    Maryville, Tn.
    434
    Car siding, huh? It's been many years since I've seen that. I didn't even know it was still available. How much does it cost now?
    All of you have seen car siding (117 siding, Thanks Allan) at one time or another. It, along with 105 siding were the preferred choice of siding materials in the days before T1-11 and other plywood siding materials. I would dare say that better than 75% of all wood sided homes built between the 30's and 70's were covered with 117 or 105 siding, except possibly in the northeastern states. Car siding came in 1x6 and 1x8 and had a twin teardrop profile. The name car siding came from a similar profile used on early railroad cars. 105 siding has a flat face with a 1 1/2" concave top edge along it's length. Both patterns have ship lap joints.
    Stayfair, I would suspect what you are referring to is actually 1x6 or 1x8 twin V-joint, which has a flat surface with a v-joint down the middle and forming another v-joint when two boards are placed together. It does have t&g edges. If it is v-joint, it is preferable to use blind nailing to install, but if you want to face nail, go ahead. It is you that will have to look at the nails.
    Paul
    15,171
    I've used truck and trailer loads of it in 2x6 and 2x8 T&G configurations, we use it for open beam ceilings because it spans 7'. Here is another picture of it in 1x8 size used as paneling.
    Maryville, Tn.
    434
    Dick,
    Your pictures are of 1x and 2x single V-joint siding, not car siding. However, many people mistakenly refer to v-joint siding as car siding since that is what they have always called it, not realizing they are two separate types of siding.
    15,171
    J~
    So it's got to have a V joint down the middle to be car siding? The 2x V joint which I show is what the lumber yards around here always called car siding. I've never heard the 1x called car siding, only the 2x, we call the 1x just 1x8 T&G. Most of the 2x I've bought was in pine in the '50s but turned to hemlock in the '60s and later.
    Maryville, Tn.
    434
    Dick,
    No. If you read my earlier post, you would have read that car siding has a twin teardrop pattern with ship lap edges. No mention of a v-joint. A flat face material with t&g and v-joint down the middle would be...twin v-joint. Your pictures are single v-joint (no v down the middle). 1x8 t&g, without v-joint or beaded edging called for, would be flat and have no profile, ie: wood flooring.
    Orange County, Calif.
    1,856
    Car siding installation pictures.
    The author describes the material used on this project as "carsiding" right at the bottom of the page.
    Materials Used:
    1x6 Tongue-and-Groove Carsiding
    2" Maze Siding Nails
    Click here to see the pictures.
    12,272
    Al:
    I did not see anything there that looked like car siding (117), it all looked like 105 siding. And the 105 siding I'm familiar with is not tongue and groove, more like lapped.
    1,856
    Alan,
    Since the author called it carsiding I thought that will be it.
    I’m sure you are right. This is another area I know nothing about.
    Mar 2005
    Illinois
    138
    What I've considered and seen as carsiding was a 1x8 with a v-groove in the middle. When two pieces are joined (T&G) they create a v-groove too.
    All that being said, I think I'll go with drywall;)
    Thanks.
    12,272
    I believe what you've described is called V Joint Centermatch. Attached is a picture of car siding, also called 117 siding.
