Re: Flashings, Leaky Windows, House Wrap, Etc
Dick, I’m not a scientist but I’m just not worried about Tyvek being compatible with the peel and seal window wrap membrane product. My stucco contractor uses the Jumbo Tex too. The two layers of Tyvek (one being Home Wrap, one being Stucco Wrap), with the Jumbo Tex as the third layer, I believe gives me a pretty good system.
However, the key I believe is flashing being installed properly and the window pans. I would guess 95% of leaks are around flashings and windows, not out in the field. I'm taking the postion windows may leak, I want to keep the water out of the house. I am thinking about on all of my stucco homes, putting in a 2x6 brickledge, and setting the bottom 2x6 plate of the exterior wall in the drop. That way, god forbid, if any water ever gets in the wall at least it stays out of the house. What do you think?
I am using the Tyvek 7†wrap under the pans (probably needlessly), with 2 layers of membrane (one before window is installed, one after) peel and seal on the vertical sides, and one layer on the top for head flashing.
My framer is one of the best I’ve ever seen. I’ve used him for 12 years. He is one of the more expensive here, his price per ft is from $5-$10/ft.
The house he just finished was not complicated as far as the roof, but it did have 11’ ceilings, 13/12 pitch, lot of arched openings (I counted over 50 today), several eye-brows, one set of round stairs going 2 stories, 1 set going 3 stories, another going 2 stories. He installs all windows and doors, cornice, decking. He’s great on detail (blocking for bath accessories, dropping sub floor for tile, following engineer’s design, framing for elevator, knows the code, etc). I’ll try to post some pictures. By the way, he has a daughter in pre-med at Rice University, another studying law at U of Houston, owns a home here and in Acapulco, has 3-4 fairly new decked out work vans, of course all the tools you can imagine. I believe he came here from Mexico in 1980.
Comment
