Results 1 to 9 of 9
    Mark Kaplan Guest
    Default Shower Pan Slope
    I know that a shower floor needs to slope 1/4" - 1', but when installing a large shower 4' x 7' do I set the float strips at 7 x 1/4" = 1 /3/4" + 3/8 and accept the larger slope on the shorter dimension. Also, if I'm using larger 8 x 8 tiles is there any concerns with the slope.
    Mark Kaplan Guest
    Default Re: Shower Pan Slope
    oops Typo. 3.5' x 1/4" = 7/8 + 3/8 = 1 1/8"
    Darrell G. Welch Guest
    Mark,
    How are you going to bend the large demesioned tile to fit the curve of the slope? You will end up cutting the 8 x 8's to fit correctly and it will look pretty unprofessional. I rarily if ever use tile larger than 2 x 2 for shower floors and never over 3 x 3. I strongly suggest you reconsider using the 8 x 8.
    Darrell
    Michael Guest
    To add to Darrell's comments about a professional look, the ENTIRE perimeter of the floor needs to be on a level plane--if not, the floor/wall junction will look like it was done with a plow.
    8 X 8's on a sloped floor? It will end up looking like the floor of that filthy restroom on I-5, and the excessive lippage will try to collect all the stuff that should be going down the drain.
    Jeb Guest
    Michael,
    Then the entire perimeter should be at the prescibed height for 7 feet no matter what the width may be?
    Thanks.
    Jeb
    Mark Kaplan Guest
    Based on these responses, the bathrooms that I have seen using larger tile must have little or no slope to get the tile to lay flat. So can I use 4 x 4 or do I have to use Darrel's suggestion of 3 x 3 or less.
    Thanks for the feedback
    steve Guest
    The dimension you need is not 7', it is the longest diagonal from the drain to the corner, which will presumably be something like 4 feet.
    Cisco Guest
    Mark,
    as MB says your perimeter needs to be level. With the perimeter level you would have a "Steeper" slope parallel with the longer wall. Unless the drain is exactly the same distance from all the walls,curbs you will have a different pitch on every side.A wood float with the corners rounded off(like a pool floaters trowel) would help "shape" the mud and give you a nice flow . 4x4 would be the max.imum size I would lay without causing serious lippage. If your using small grout joint say 1/16 or 1/8 lippage could be a problem, a 3/16 should cure that. If your tiles have rounded edges that would help even more.
    Cisco
    Tim Carney Guest
    I am removing a bathtub, 30 years old, and replacing it with a ceramic tile shower. The shower bed will be 31" x 60". The drain is centered. That means that across the 15"@center I would have only 3/8" slope? Then across the longer side, 30", I would have 5/8"?
    Also, looking at Michael Byrnes' article on "Morter Bed Shower Floors", I am putting this shower on an existing concrete slab floor. What parts of the layering can be skipped or altered for slab applications? I am useing a waterproof wallboard. Should I also use the cement backer board? Thanks, Tim
