Results 1 to 6 of 6
    SRS Guest
    Default Covering wood foundation
    Hi,
    I am looking for ideas to cover a wood foundation from just below grade to the siding. The foundation is covered with foundation sealer (tar)and black plastic. I would like to make it look better where it leaves the ground up to the siding. I have seen a product called groundbreaker, made of fiberglass but it didn't look to good. Hardiboard is not recommended for exterior, but it would be easy to coat with cement and would look pretty natural. Any ideas would be appreciated.
    TIM WILLIAMS Guest
    Default Re: Covering wood foundation
    SRS,some companies that make pressure treated decking also make pressure treated plywood,that might help,
    Jim B Guest
    We use wood foundations all the time, especially on additions in tight spaces. They can be parged easily using the same methods as stuccoing (paper, wire, scratch & finish coat)
    Jim B
    SRS Guest
    Could I expect the stuccoing coat, wire and paper to hold up.? I want to be able to bury it a little below grade so I don't have to look at the wood.
    Jim B Guest
    It seems to be holding up fine on jobs done as much as 10 yrs ago. I am sure it would stand up fine even longer. It is the same as parging, a portland cement based product, and the wire is galvanized so it should last a long time.
    Jim B
    SRS Guest
    Thanks Jim,
    I'll probably have to talk to a stucco contractor. That sounds like something you need a little practice with.
    Steve
