Results 1 to 5 of 5
    Bryan Klakamp Guest
    Default Repairing crack in knockdown ceiling
    I have a hairline crack in a ceiling with knockdown texturing. What is the best way to repair it? Without redoing the rip joint, I thought about latex caulk in the crack, and then repainting. Good or bad idea?
    Bob H Guest
    Default Re: Repairing crack in knockdown ceiling
    What's causing the crack?
    Bryan Klakamp Guest
    I don't know what caused it. We used fiberglass mesh tape and 90 min. easy sand compound to set the tape and first coat. It's on a rip seam and is about 4' long. It is just a hairline crack, no compound has cracked out of it.
    The house does shift from winter to summer. I assume that this is the reason for the crack. The homeowner is checking it over the winter and into spring to see if it changes at all. It very well may close up as warm weather gets here. The house is located in NW Ohio. It is in a sandy soil area.
    Depending on what it does this summer, I wanted to use something that would give if needed.
    Thanks for your help.
    JohnNH Guest
    Bryan,I say it was the fiberglass tape,use paper next time.JohnNH
    Myron Ferguson Guest
    I use paper tape on all my butt seams because it is stronger. For now caulk may work but it will look different when you paint it, so cover it with a thin layer of compound before painting. If you have to retape the seam it is not to hard to blend in a knockdown texture.
