Windows 7 Login
  • Windows 7 Login
    Every time my computer goes into sleep mode and I shake the mouse to wake it up I have to log in. This is a home computer. How do I change that so that it opens up to my desktop? tia
    Re: Windows 7 Login
    Im on XP - may be similar.
    Looks like your set up with a password from "User Accounts"
    Go to > Control Panel > User Accounts
    In the Help section look at "Change or delete password" it will give you further instructions.
    Also look at >Control Panel > Power Options > Power Schemes
    System Standby > Never
    System Hibernates > Never...........is what I have set.
    Might want to try this first.....
    > Control Panel > Power Options > Advanced > Uncheck - prompt for password when computer resumes from standby.
    Steve
    "Get three coffins ready" - A Fistful of Dollars 1964
    http://youtu.be/KZ_7br_3y54
      Re: Windows 7 Login
      Not a good idea to assume anything is the same in Windows 7 as it was in XP. Some stuff is very different.
      The issue here is that it wants a password to logon after you have left the computer for awhile.
      Assuming you have and want to keep a password when you turn it on then you need to remove it from when it wakes up. Go to Control Panel > Power Options >Require a password on wakeup. Set that to require a password or not on wakeup.
      There is another setting that is available where you can have a password required when the screen saver has come on but the computer has not gone to sleep. Go to Control Panel > Appearance and Personalization > Personalization > Screen Saver. There is a radio button and if checked it will require the password when you clear the screen saver.
      There might be some reasons to not let an XP machine go to sleep since sometimes they don't wakeup properly. Any decent Windows 7 machine should do that well and no reason to not save heat, energy, money, etc.
        Re: Windows 7 Login
        Very good answer Greg !
        Steve
          Re: Windows 7 Login
          Click on "Start", then type "netplwiz" into the start menu search box, hit enter, and a dialog box will come up. Then uncheck the checkbox that says "Users must enter a user name and password to user this computer."
          You can get to this dialog box other ways but this is the easiest.
          HERS Rater • BPI Building Analyst • BPI Envelope Professional
          Certified Green Building Professional • Certified Existing Home Advisor
          General Building Contractor • Asbestos Certification • Hazardous Substance Removal Certification • EPA Approved Lead-Safe Contractor • Locksmith
          PMP • ESEP • CISSP
            Re: Windows 7 Login
            It's fine to disable that - I do as well on machines that only I use - but PLEASE do be sure you're using a strong Windows Password when you log in initially.
            JLS
            ((Planning + Process) x Technology) = SUCCESS!
            Joe Stoddard
            Mountain Consulting Group, LLC
            Twitter! http://www.twitter.com/moucon
            How can we help you achieve your goals?
              Re: Windows 7 Login
              Greg,
              It was your second option that did the trick. Although I did not have to login in after the screensaver went into effect when it woke up I had to click the login screen to open up my desktop which was one additional step I did not want. Thanks for your help as well as others that responded. You all always help me out in time of technology need.
